What's wrong with the b.lee kits? I wad thinking about one
Not knocking B.Lee's kit but some observations between the two.
CavFab boxes in the control arm mounts, making them less apt to bend.
The shape of the cross member being angled in the front to better to slide over objects vs rectangular tube of B.Lee
I may be wrong but with cutouts for the drive shaft and exhaust on the CavFab crossmember the may mean a little more clearance.
There are side plates in the CavFab kit that bolt to the sides of the frame rail for added mounting strength.
Both run a Currie joint at the upper axle mount. As for the other control arm ends, I can't argue heims vs. Currie joints/poly bushings, I don't have experience with them.
B.lee will customize their arms with different ends if you like.
Both have a t-case skid in the works too.
CavFab regular price is a bit higher than B.lee's
