I will also verify that the springs with the kit do not work, even though COMP initially told me that one set would (926-11 or something?)
The springs are much larger diameter than the stock ones, and don't sit properly without further machine work on the head (which is do-able, but why?). Then, the stock valve retainers won't work, and COMP doesn't make a retainer for that spring with an 8mm valve stem, so you'd have to put different valves in at the same time.
The MOPAR P5249464 spring and P4452032 retainer work well - you can use the stock valve locks, or purchase new ones, they're actually pretty cheap compared with $12 per spring and $10 per retainer (I think one "bag" of them from summit was $19.99 - it was listed as only doing 4 cylinders (8 valves) but had enough to do all of mine!)
I just had my COMP cams SK68-232-4 cam package fail during the break in procedure. Turns out it chewed up all the lifters (which all had the appropriate bore tolerance and dropped in smoothly and rotated freely when new) so badly that it wore holes in the bottoms of two of them, causing them to catastrophically lose oil pressure and not open the intake valves in cylinders 2 & 3 at all. Then the lifter not keeping pumped up caused it to slap the cam as it rotated instead of keeping continuous contact, which wiped the cam... :flamemad:
Oh yeah, they also sent me the cam with the sprocket pin in the end in the wrong hole (180* out), so when I put it all together and timed the motor, #1 was firing when #6 was TDC compression stroke. Luckily, the 4.0L motor is symmetrical, meaning you can just spin the distributor 180* to correct the problem, and it fired right up instantly. Still was an annoying problem to troubleshoot...and it ran great for 15 minutes until the lifters blew out.
Just makes me wonder about the tech and/or QC system in place at COMP - potentially careless assembly, people telling you one product works then being contradicted by another (who is correct), and following ALL of the installation and break-in procedures to the LETTER (including the use of break-in additives!) and having parts fail almost instantly. (For reference, the 100,000 mile cam/lifters i took out showed almost no wear at all, just a super-slight cupping on the bottom of the lifters)
~Brad
