C8.25 door sticker questions
FuzzyXJ
Indiana
Does anybody have a link to the codes on the door stickers for C8.25 axles? I know ford has and if you know the codes you can find the gearing and whether it's open or LSD. I want to do the Liberty drum to disc swap and am planning on just getting the entire axle off a Liberty. I already have LSD in mine but would prefer finding one with an open diff so that if I want I can swap the carriers out to put in a locker down the road.
Jeep axles have axle tags on a diff cover bolt, that often is long gone. Anytime you buy a used axle you should look inside, so identifying the gear ratio and the carrier type is simply a matter of looking at what's inside.
