Built 8.8 Rear Axle
YZRacer408
Mission Veijo
This is a professionally built ford 8.8 rear axle. Set up for a TJ Wrangler. The axle is out of a ford explorer so its a 31 spline with disc brakes. The good 8.8
Everything on this axle is absolutely brand new with ZERO miles on it just used for mock up. Has every upgrade you can throw at an 8.8
Axle includes:
New Motive Gear 4.88 ring and pinion (installed)
New Detroit Auto Locker
New bearings, seals and gearing build kit
New 31 spline Yukon Alloy axle shafts
New Artec industries truss kit and TJ axle swap kit
New calipers and rotors
New Currie Brake lines
New 1310 flange adapter
New Ruff Stuff Specialties 3/8 diff cover
This axle is set up and ready to be ran in a Tj wrangler just bolt it in.
You Could very easily cut off brackets and weld perches on to put under an
XJ cherokee.
Interested in the axle call/text Scott at 714 873 4111
Text for pics the forum wont let me upload pictures
$2500 obo
