Mr.OverKill
- the city of El Cajon
for the frame side and was wondering what you all have done, just for some different ideas.
for some background, when i put the radious arms on and moved the axle forward, the coil started to rub the mount so i needed to move the track bar mount so the coil would not rub it any more and to get a little more clearance on the track bar and axle, pluss i am modding the track bar to eliminate the OEM frame side ball joint and going with a bushing there ( trail only so it can have a rubber upper and lower ) since i am changing the style of track bar and moving the mount the holes wont line up any more, why not build a new one with more beef any way.
i am thinking 3/16 plate 9.5 inches top to bottom with a 4.5 inch flange going under the frame ( like this -I ) and on the bottun side a 4 inch piece of 2X4 3/16 wall tubing with gussets added and notched to accomidate the track bar. for added ridgity i will run 2 pieses of 1X1 angle down the veritcal plate.
so inputs and ideas are welcome. by the way this will be welded in place plus some bolts that i can make work.
