Build thread: Out of Misery, again...
Can't wait to see this in person when its done!
X2.
I'm not a fan of their front LAs but so far I kinda like the rear set up they got going on. It makes me wonder if they will make a trianglated upper kit for the ZJ like claytons.
They look like 1/4". They should be fine for uppers. Clayton's rear uppers are about the same way with lots of ZJs using them with no issues that I've seen.
Claytons. I used a Barnes mount for my rear uppers which I like a lot. I think that IRO will be ok though.
Any chance it will be in KY in July?
There is not much room fro longer springs under the "frame", if you were to inboard them then you could use longer springs.
You can use long springs, they just need to be a light rate. I'd look into dirt oval springs
PAC has a variety of 20" spring with a bind height of 5"
dang Dan, spending that $$!!! Oh, did your social security checks start rolling in? :D
