Lowrange2
- Abbeville, SC
Fellas!
I'm finally able to post within the confines of the MJ forum as I'm going to pic one up this afternoon.
I got this thing dirt cheap. Had it not been dirt cheap I wouldn't have bought it since it's not my ideal factory build.
The truck...
1988 Comanche (I have no clue on the trim) Base?
I4 (This was the part that wasn't ideal)
2wd (This wasn't ideal either but it's fixable)
Manual transmission
SWB
The body is fairly straight, all things considered. It runs, that's a plus. It moves under it's own power, that's also a plus. But that's about all I know at this point.
The truck obviously has a few issues.
Things that I know need attention:
Clutch - The guy says the clutch needs work. He says that it won't disengage (no pedal) which tells me that the slave cylinder is either bad or leaking or empty.
Drivers door - Apparently the PO fubared the door hinges and the striker bolt. How he managed to do that I'm not sure but from pictures I can tell that I'll need to graft new door hinges into the body as well as a new striker.
Floorboard - The door has been in a state of dissrepair for 2 years. Therefore, the drivers floor has rusted nicely. I've yet to see it but I'm sure it'll need to be replaced.
Paint - obviously
None of these are really big deals to me, I really just want to fix the truck up kinda nice for now. Get it running well and look decent. I think I can accomplish that with a bit of your help.
Once I get to that point I'm sure things will get out of hand and it'll be on 60s, 38s, and a LS2.
First line of business is the clutch. I need to learn how the clutch system works on these things. I have no clue right now. I've been told that on the I4 Comanches the slave cylinder was external... I hope this is true. I really don't want to have to drop the transmission quite yet.
I've searched for the past 2 hours and have yet to find a definite answer which transmission I should have. If I'm reading correctly, I have the AX-5? Which transmissions came behind the I4 in 1988?
What are some things I need to look for on this thing? I know there are a lot of rare builds, and this one is probably as normal as they come but is there anything special I should look for?
I'm quite interested in what trim model this one is. You may be able to tell me from the pictures that will soon follow. Can I run the VIN on a model this old and get a build sheet? If so, where can I go to do that?
Things I know I'll need:
Tailgate! It doesn't need to be mint, just lite on the rust! I can't believe no one makes a aftermarket tailgate for these things.
Door hinges. I should be able to fix what I have but if push comes to shove I'll cut up a lucky Cherokee.
Welp, here's a picture of the beater.
Dirt cheap! Like less than one of my cell phone bills.
The truck...
Manual transmission
SWB
Paint - obviously
