Brake help needed
WAxj90
Washington State
I went to change my front brade pads a couple days ago and one of my front calipers was frozen so I decided to change them both out. At the same time I cut and removed all the wheel sensors for the ABS system. But now I get no pressure the pedal just goes to the floor. So I did what people suggested and removed all the ABS stuff and put in a booster and M/C from an '86 xj in. It was a perfect fit but I still dont have any pressure. I've bleed the brakes twice picked up a new M/C, checked for leaks, bleed the M/C before install. I'm stumped on what it could be. It's a '90 Xj I-6.
Thanks
Dillon
Did you bench bleed the "new" master cylinder before (or after) you installed it?
