RadioShackSpecial
- Michigan
I just finished up a complete brake job on an older Buick. After doing the typical open bleed valve, push pedal, close valve trick for bleeding the brakes Im looking to pick up something to make that part of the job easier.
What do you use/recommend? Speed bleed valves or Vacuum Pumps? I would like to keep it under $100 if possible but Im not afraid of spending more on a good product.
