Booster/Master
Marc, i'm interested in it. this is the dual diaphram one, right? good upgrade over my 91xj one?
Same here I want to upgrade and get rid of the rest of my abs
oh i got rid of my abs long ago. havnt seen them in many years. though i now have a place to rest my beverage.
Get a WJ booster and master cylinder. Follow starboardm's write up on it. I did the swap from abs to the WJ stuff.
95/96 dual booster/mc is basically the same. So I guess whichever is cheaper?
The WJ just fits a little better under the hood of the renix. Don't have to move anything. The washer bottle has to be moved with the 95/96 booster
Ahh I read one write up on doing the upgrade but there was no mention of how to get rid of the abs.
You simply take out everything brake related besides the lines. All that electric pump stuff and lines on the little manifold. Pretty much gut the system and keep the lines. Which you'll need to bend to get to the prop valve. Your current system
Does not use all of the ports of the prop valve. But the lines can be moved to work. Pm me if you have questions about it
Will do
