Root Moose
- ON, Canada
Hey gang,
I pulled the engine out of my '88 Comanche (blown) and am debating what to do with it.
The engine was overheated before I got it and it seemed to still run fine while it was cold but the cooling system is pooched (brown oil and coolant) so I'm thinking it is just a head gasket.
No rods through the block or anything like that. I haven't opened the engine to verify though.
I'm putting a ~160k mile '98 drivetrain in the Comanche and figured once it is all swapped, painted, sorted and stuff I'd do an engine rebuild/stroker the following year.
Can the RENIX block be used in a OBD-II Jeep for a stroker build?
Will the accessories bolt up?
Is it worth the bother or should I take it away for scrap?
I was thinking that since the RENIX block is supposed to have a higher nickel content than the ChryCo blocks it might be worth keeping around to build off it since it will wear harder/longer.
I don't want to storing this block for a more than a year if it isn't easily usable. I'd rather send it on to the wrecker now and get a bit of beer money back.
Thanks.
Thanks.
