- WA state
What is the stock rocker ratio and are there any swapable better ration rockers? For example, when I had my dakota, they had 1.6 RR, and there were 1.7 RR available as a swap. Is there anything like this for out 4.0L?
He said he has some, waiting for a response. Unless the valves are really that close, I do not see why a little extra lift is bad. It made a world of difference on my dakota.According to mopar(mopartsracing/jeepconnection.com), the stock valve springs are good up to .43" lift max(P4529215 are the replacements for 88-02). Now Mopar recommended their use for the P4529228AB cam(.43 lift) and the P4529229AB cam(.44" lift, which is more than the max lift they rec), but not the P4529230AB cam(.45" lift, they recommended the P5249464 springs, good for .525"). So how do the lifts change when you go from 1.6:1 to 1.7:1? The 87-95 cams are .424" lift on both intake and exhaust and will now be .457". The 96-01 cams are .408" intake and .414" exhaust and will change to .434" and .44" with the 1.7s. I used http://www.wallaceracing.com/rockercalc.php to calculate. So the question is if you use the 1.7s on stock springs, when will they bind? It seems that it'd be safer to try on the 96+ cam since the lift is less, but I'd be wary what happens come 4500+. Maybe someone who has used the 1.7s can chime in with their experience and setup.
What year is your XJ, did you change valve springs?Stock is 1.6:1. I put the Yella Terra in mine 1.7:1.
http://www.yellaterra.com.au/produc...37&modelIdentity=23&productCategoryIdentity=4
Ordered them from Patriot Performance.
https://www.patriot-performance.com/xcart/product.php?productid=139&cat=60&page=1
I don't know how much it gave me. I did the exhaust, header back, Throttle body, K&N FIPK and gears all at the same time. Big difference all together, but don't know what each one seperatly did.
I swapped 1.7s in place of 1.6s on my 92 dakota with a 318, and no issues. I know the 4.0L is different, but do not really see them being affected that much.I'm wanting to recall that the OEM RR ratio is 1.6:1, so you'd need 1.65:1 or 1.7:1 (unless I'm wrong. I haven't thought about that end of things for a bit...)
Note that going with higher-ratio RRs generally does require a change of valve springs, so you don't "go solid" before you get to full valve lift - then end up breaking something really important!
Thats why I want someone to chime in on the spring compression height at 'x' ratio stock and how much farther the spring will compress.Note I said "may." It depends on what springs you would have, and at what lift height they'd "pack solid" on you.
If they'll support the higher lift, you're fine. If they won't; the first time the spring packs, something will break. Period.
