Best XJ?
mrbell83
In the mitten
Hey guys, I am a noob, and I don't even have a jeep:bawl: I am however getting ready to purchase one in the nex few weeks. I am looking for something to be my DD but with some off-roading, currently I am looking at 95-00 models. Are there any years that are better than others? Also what about rust and common problems, did some years have better track records for quality? Also, what kind of miles can I get out of one of these? I drive allot and I really would like a new vehicle, but I love the XJ, always have, and I have never owned a chrysler vehicle so all this is new to me.
Any help/advise would be great.
Thanks,
Chris
first off, welcome!
Not trying to be a hard ass or anything, but all the questions and concerns you mentioned are very much covered on this site, and get repeated often. If you'll look to the top of the page you'll see the search button. Type what ever you want to know in it and I gaurntee you sevreal pages will come up and answer your questions.
Ohh and my vote goes for a 99...but I think i'm a little biased..
Thanks for the welcome, sorry if I have posted something over again. I am 23 but not the internet forum type. I will try searching.
thanks allot,
Chris
i have had two 2000s and mine have been fine but others have issues... the 00-01s went distributorless, they got precats on the header (which means more retrictive exhaust and less of an aftermarket header option if ur going this route), both of mine, dont know if this is common, but ive had to replace the wheel ujoints in the front on boh around 70000 miles...they make for a really bad rubbing/creaking/clicking noise and a little wheel hop at tight turns, I think they also switched to the Low pinion dana 30 for 00 and 01 (it could have changed in 96 though so u would get one anyway if this is the case)but ive heard both so u might want to see what year this occured..the Hi Pinion d30 is a lil better in that it doesnt give out as many driveline vibes..also the 99 and ups had the 0331 head on them which has been known to crack...some get lucky and some dont... like i said i love my 00s but if i had found naxja before my second buy i would have gone with a 99...i was a stupid when i had my first xj and i really beat the piss out of it, bad, i kno they are rugged but i trashed it like a fawkin idiot...nothing ever broke on me or went wrong other then those u joints and my alternator...the 00 i have now i baby it...take real good care of it and those ujoints still went so i dont kno...also the electrical on a 00 is a little different some how...my alternators have sucked..they sound like my cherokee is making boost (its just the bearing inside tearign themselves apart.. cute huh?) replaced the one on my first 00 and will soon be replacing the one in my new one...
i've had some minor issues yes. but both of my xjs have treated me well as wheelin Daily drivers... i would go with a pre 00-01 xj if i had to get a new one but if u must get something in this year range im assuring u there not terrible
hope all this helps
andrew
to be honest, I would look for an early 99, still have a coil/wire/cap stuff, yet got the larger intake and no pre-cats, and still has the HP Dana 30. After that is really depends on what you find, are looking for and can afford.
I have had an '87, and now currently have an '88. I like them because they are easy to work on, and they are bulletproof. Mine has 251k+, and still runs like a champ(as soon as i can get the alternator on).:yelclap:
I would like to make a comment on the head castings. I have a late model 99 (september build date) and I have the 0630 (the good one) head. This seems to be the extremely late build 99's that have the 0331 in it. Definately something to take in to consideration when looking.
it says your in the mitten so i would assume your in meeechigan like me. If thats the case i would look for this.
1. NO RUST.
2. The fulltime transfer case called select track aka nv 242, it allows you to driveon dry cement with 4wd. Great for the michigan commuting when its half snowy half not or the center lane is snow but the right lane is dry'd up etc. If you find your dream no rusty XJ and it has command track aka nv231 then dont sweat it. Given the choice go with the select trac nv242
3. get the 4.0 dont waste your time with a 4 cylinder.
If you are in michigan find a nice clean low/no rust Cherokee. Mines a 1995 and almost ZERO rust overal but about 3 years ago i pulled up the carpet in back and had rust about the rear leaf springs about 3 inch.
This spring my dang passenger side rocker rusted from the inside out cause i previously treated the outside with POR15 rust treatment and coated with herculiner.
Check the solidity of the ROCKERS in michigan !! With out confusing you with minor details each year, the cherokee was mostly the same vehicle with major exceptions being it got dual air bags in 98 redesign/tweaking, slightly new body panels, slightly less engine noise, different cam, different intake etc. NOTHIGN that is a world of difference.
I'm only offering my opinion because you are not hunting on the same grounds as I.
I would get the 97+ with the 8.25 rear end. This will give you a 29 spline axle that is reportedly almost as strong as a D44. As far as the transfer case, it depends on what your application is going to be. If you want to drive in 4hi on the street (even in snow and rain) I would go with the NP242 because it gives you a full time option. If you only want to use your XJ for off road, then the NP231 is a good choice becuase there are a few 4 to 1 options for it (note: there may be some 242 options, but I am about as new as this guy, so I haven't looked for em yet) If you can get it, get one that had the FACTORY towing package. This will give you the possibility of 3.73 gears..which isn't great if you are planning to go big, but it is better than the normal 3.55 (for the manual transmission).
In summary:
Look for 0331 casting number on the head = Bad
Engine: 4.0 L
Transmission: AW4 (automatic is what I preffer)
Transfer Case: NP242 - "Selec-Trac" (NP231 is fine too depending on your application)
Front Axle: Dana 30 (no choice)
Rear Axle: Chry 8.25 (97+ had 29 spline, <97 had 27)
Gears: 3.73 (towing package)
Stock Armor (although I've heard mixed reviews on their durability)
In summary:
Engine: 4.0 L
I am still waiting for somebody to show me a factory tow package with 3.73's in 87+ XJ. I have a 98 classic, that had both the factory offroad and towing group with an auto and I got 3.73's. They were a possiblity in 84-86 XJ's and early model MJ's but have yet to see an 87+ XJ with 3.73 from the factory. Though they have done weird things for 4cyl auto XJ and TJ, like 4.56's from the factory.
Wow guys, thanks for all the info. I have writen down the info for the heads, I want the auto with the 6 cyl. and I don't really care what kind of Xfer case it has. It seems that my options are limited for a 1997-00 with under 100k for 6500 or less. I wouldn't really care what year I got but as mentioned, I live in Michigan so the salt is cancer. Also this will be my DD and I don't really care if I have to put a motor in it because I have always wanted one of these and plan to keep it for a while. I was wondering tho, how many miles can one get out of a well maintained 6 cyl with the auto trans? Is buying one with 80-90-100k on it too many miles?
Thanks allot guys, all this info is great. I love Jeeps. :firedevil
my 00 just turned 90000 and is perfectly fine....
my step dads 91 went for 202k before it turned into a major turd he then decided Japanese was better and bought a :puke: camry,then a :puke: FJ Cruiser
he should have stuck with jeep:laugh3:
Thats about, to even a little less than half of what alot of them are getting if properly maintained.
The 4.0 and AW4 (the only automatic tranny offered with the 4.0) are an excellent combo and extremely hard to beat as far as reliability goes.
There are several threads about this, if you care to search for them. There are many XJs out there running strong with 300,000 miles or more on them.
