xj92
- Junction City, KS
I installed a Taurus fan in my Comanche and now need a 3-way switch to finish the wiring so that when the top is pushed in it will be on the temp-controlled low-speed fan setting, in the middle would be both fans off, and pushed down would be constant on for the high speed as long as the ignition is on. I have a carling large rocker switch that I love the feel and size of, and the lighting on it, etc. But it's only 2-position. I've found the part #'s for the 3-way switches I want, but can't find any place to sell them to me unless I want at least 14 of them. I only need 1 or 2. Does somebody know a good place to buy Carling Rocker Switches, or know of a comparable brand or product? I want something that shows a different color of light for each position that the switch would be in and something that is about the same size as the stock rocker switches (aka full-size rocker, not mini). Here are part #'s I found:
• LS1560-31-BL-BL-012
• LS1560-34-BL-BL-012
• LS1560-41-BL-BL-012
• LS1560-43-BL-BL-012
