best exhaust header
RedChuck
Delaware
so any opinions on the best options for headers? I'm getting ready to fab a larger exhaust for the beast and might as well up the exhale of the 4 O
Went from none cracked (welded) stock to a knock off apn. No real power increase or mileage, but sounded a bit different. Maybe throttle response was better.
Then to a pacesetter with a custom 2.5" downpipe. Feels healthier in the midrange for sure. Easily noticeable. But driveshaft keeps taping it.
So I now have a ceramic titanium coated jba that has a 2.4" inside diameter collector. Similar to stock design so I don't expect much. But that with a 2.tl5" downpipe should make a ok difference.
Pacesetter would be great if the flange was thicker. It's got the longest primaries availiable and makes a difference you can actually feel.
I've been running the Doug Thorley Headers HDX‑634Y since ~2011. T304 stainless and ceramic coated inside and outside, essentially rust proof. I had a weld fail a few months ago, I sent some pics, they said the wrong welding wire was used and warranty swapped a new one. Expensive yes but its probably the best or very near to it.
