Bench Bleed Master Cylinder?
banderso
Stockbridge, MI
I'm almost done getting my '45 MB on the road. I have rebuilt or replaced every part part of the brake system from the master cylinder to the wheel cylinders. Is it necessary to bench bleed the master cylinder? I don't really understand the purpose of bench bleeding. What does it accomplish that can't be done by just bleeding the brakes?
In the past I have always had someone pump the brakes to bleed them. Can I do just as good of a job gravity bleeding them instead? Do those vacuum brake bleeders work?
Yes, you do. The only other way to make sure you get all the bubbles out of the M/cyl will be with a pressure bleeder, which I presume you don't have.
Those vacuum bleeders work quite well - I've been using them for years. It's kinda nice not needing someone helping you when you bleed your brakes...
there are two other variations on bleeding, but I went with bench anyway. The bench method lets you tap on the MC to dislodge the tiny bubbles.
With the MC on the jeep, a syringe can be used to inject fluid into the front and rear ports (with a filled resevoir, shot by shot the air will displace out.)
A second method off the jeep, which might not work on a dual circuit, is "immersion bleeding". The entire master is submerged, and pumped under a bath of brake fluid. Very messy, but also the lowest tech method to ensure no air is trapped.
No matter what method, an MC bleed procedure is a must.
Alright, I'll do it then. Thanks. That's the answer I was expecting, but not the answer I wanted. I have not idea how I am going to get the master cylinder back on the vehicle and attach the brake lines before all the fluid drips out.
As for the the vacuum bleeders, can I just get a cheap one from the auto parts store? Or will some work better than others?
Can't you explain this method a little further?
get a few rubber pugs from the hardware store...use those in the ports and snap the cap for the resevoir on before installing the m/c and you should be able to keep fluid loss to a minimum.
Yea, I will. Thanks for the tip. It's just one of those things where it's kind of hard to get the brake lines to start threading in. It takes a couple of tries and a little bit of time. I'll get it to work though.
very little fluid will leak out, just enough to form a small bubble. The MC wont empty quickly, it has internal valving to stop that, it will just dribble slowly.
I cant recommend a pressure or vacuum bleeder, i used bench, gravity and speed bleeders.
Mity vac seems to be a favorite around Naxja.
Interesting reading, but the tech hurt my eyes in here, the Non-Tech forum...:bawl:
Yeah yeah yeah...shut up, I know. :D
