denverd1
- Dallas, TX
Yes but it's switched via ign switch. So hook at to batt 1, and let isolator/combiner connect the two when ign is on
So I was looking at a wiring diagram for an automatic isolating relay... in this case, do you connect the alternator directly to each battery?
Thanks,
Mike
Personally I'd not use that isolator/ whatever.
If you remove the nut, the plastic piece comes right off. Then you can just put a non-conductive washer or two on the stud.
