i had my 31x10.5x15's on stock steel rims and never had a problem with rubbing. now i have them on stock aluminum rims and they rub at full lock. do these rims have different backspacing?
Where is the rubbing. Something I noticed with the aluminum is that the bead lip is wider than the steel. Is the bead lip on the rim rubbing the swaybar bracket? I had to bend my swaybar bracket in just a little to keep the edge of the aluminum wheel from rubbing it.
