Classicfury3
- North Carolina
Selling all my parts, I don't have any build time anymore, my loss, your gain.
UPDATE 30SEP09
This is everything that is left, everything is OBO!
1975 Ford Dana 44 High Pinion, all brackets cleaned off. Stock 3.54 gears,
open differential, stock axle shafts. No knuckles or brakes. $200
Dana 44 BRAND NEW 4.88 gears and Detroit locker. Installed in 1978 Bronco
housing, stock shafts, no knuckles or brakes. Installed, have never even
put the outer knuckles on it. $450
Buy both Dana 44's for $600
HarshTerrain High Steering setup. I would like to sell all of this at the
same time. Chevy flattop knuckles, machined and tapped, Brand new ball joints.
Chevy small bearing spindles, disc brake brackets, remanufactured calipers
with Brand new brake pads. Harsh Terrain Highsteer arms, 4 one ton tie rod
ends. Also, brand new Ford Hub and rotors, 5 on 5.5 pattern, with lightly
used Warn premium hubs. This will make either one of the above axles complete
hub to hub. I paid over $1100 for everything you see here, I would like $1000.
More pic availible on request.
1975 Ford 9" rear axle, big bearing, 31 Spline. BRAND NEW 4.88 gears and
Detroit locker, installed with 0 miles on them. Stock axle shafts, no brakes.
$500
Shackle box Kit MSRP$135.00 Will take $100
http://www.hdoffroadengineering.com/products/xj-shackle-relocation-kit
XJ Frame Stiffeners MSRP$130.00 Brand new, sorry no pic looks exactly like
website. Will take $100
http://www.hdoffroadengineering.com/products/xj-frame-stiffeners
XJ Front Frame Stiffeners MSRP$120 Brand New, no pic looks like website
will take $100
http://www.temper-mentalracing.com/TMR/Parts_and_Services.html
Tom Woods XB Driveshaft, 31.5" to 34.5". I think it is for 4-6" of lift.
MSRP$299 Want $175.
2 OME Shocks, Heavy duty 10" travel, 14.5" compressed 24.5" extended. MSRP$160 I want $60
Also have stock xj leaf springs $25
Milemarker 12000 winch
Too big for my Jeep, worked when I bought it 2 years ago, has sat in the garage ever since... No fairlead, cable looks good, definately used...
would like $250 for it...
UPDATE 30SEP09
$500
will take $100
MSRP$299 Want $175.
