BaaronVonCarey
- Brea
Got a few axles and stuff I need to clear out:
1. Low Pinion D30. 4:88, 30 spline alloys, ARB Air locker, Rancho Diff Cover. Compete disk to disk. - $950
2. High Pinion D30. 3:55 Aussie locker, new ball joints, new unit bearings. - $400
3. Low pinion D30. 3:55, aftermarket passenger side upper control arm mount. - $very little
4. D44. 3:55 limited slip. Came from Comanche, so has spring under perches. $200
5. D35. 3.55 all stock. - $Heck, Ill pay you to take it!
D44 4:88 gear set - $50 or will through it in for free if you take the d44 axle.
(4x) 32x11.5x15 BFG AT's on black steel "pacer wheels". Wheels are in good condition, tires are getting a little low on tread. - $300
Located in Whittier
Located in Whittier
