DIRK COLO XJ
- rocky mountains
Help, I need some Qualified opinions on the +/- of the AX-15 5spd. vs. the NGV 3550 5spd. I have a 99 XJ that came with a AX15 that can double as a air raid siren. Yes it has the correct MOPAR GL-3 lube the factory uses,but the former owners took it to jiffy lube and the trans recieved some of the generic sycro bearing eating stuff. I want to replace this AX-15 with a NGV3550 as Iam told this is a direct bolt in replacement used in 00,01 Cherokees and TJs BUT is this tranny any good? ie. noise, shifting,reliability? Has any had both transmissions? many many thanks Dirk
