SpikeSpeigel
- Stationed in Jacksonville, NC
Ok... Symtoms: Park= Park (unless placed in park after cycling through gears, then it jumps forward and hit's some osrt of stop). Reverse= nothing, not back, not forward. Neutral= It will go forward like it's in drive for as long as I want. D, 3, 2-1= They all work fine. Also, the engine will not rev over 2700 rpms.
It has been filled with fluid since running about 6 miles with little/no fluid. Tranny fluid leaks out of where the engine/bellhousing meet. Linkage all looks fine and adjusted. No binding it the shift lever.
I'm at the point where unless someone can shed some light on this, I'm going to replace the transmission today. It's the only day I'm going to have to work on it in the next month and I need to get to and from work. I read on here about checking the TCU. How do I test that? I found a tranny for $350. Let me know what you think ASAP please... thanks
