sacem
- Lima, PERU
I have a problem that arises everytime the weather is mildly cold (50ºF) the AW4 trans in my 90XJ 4.0 L with 2" raise, 31x10.5 tires Limited slip up front, stock motor, trans and diffs.
The car will not move for several seconds specially in Reverse, in Drive it will crawl but without much energy (will not go up a garage ramp) until it seems like it fills up and then suddenly it will kick in even with a tire screetch (specially in Reverse).
The problem can get much bigger if the tem goes to the 40's as then it will simply not move in reverse (I have to get out of the XJ and push it to get it out of the parking lot) and shifting to Drive will start things moving, at those occasions i will have to drive several miles before the Reverse will work.
Also when its cold the AW4 will not upshift when driven unless it is flooring it and going up to 3,000 + rpm's then it will shift when I lift the foot from the gas after 2 or 3 bursts like those it will normalize.
The trans up and down shifts normally, kicks in very nicely on the highways, downshifts with no problem in the city and the rest of the time simply works perfectly.
Can anybody give me some clues about the reason for this.
SACEM
SACEM
