average vacuum pressure
gian
az
What is the average vacuum pressure that you guys are seeing on the (91) 4.0? I'm reading, from the manifold, 16 in. Hg, with the needle bouncing around slightly- never a full division of deflection- at idle. Is this normal on these things? The engine was rebuilt 1000 miles ago- is my reading a shade low because the rings still need to seat right?
16" at an idle is about right depending on your altitude. Ideally it shouldn't be bouncing around, but if the engine is new, that is to be expected until the valves and rings seat.
