Most people just go the smart route and Turbo theirs.
If you search i believe there are a couple people who have done it. Most people just go the smart route and Turbo theirs.
Care to elaborate on that................:dunno:
I have heard of less than 5 running turbos on xj's out there, and maybe 10 Avenger setups. It's pretty rare either way.
the whole mtyh that turbos are only good for topend power is just bs. a proper turbo set up will give plenty od power on the bottom end. If they didn't my cumins wouldn't be able to put down torque in the 1000lbs rang at alittle over 1200 rpm
the 5.9 doesent but the 6.7 does have a VGT.. I have one off a 6.7 on a self right now waiting for me to figure out how to make a decent controller for the variable system so I can use it on my 5.9 and maybe if I do a all out drag jeep I'll use it on a 4.0.
x2the whole mtyh that turbos are only good for topend power is just bs. a proper turbo set up will give plenty od power on the bottom end. If they didn't my cumins wouldn't be able to put down torque in the 1000lbs rang at alittle over 1200 rpm
