Aux fuse box
XJensen
Sacramento
I am looking into adding an aux fuse and relay box to properly run some electrical. I am looking at the following but was not sure if I need the relay side bus too, dual bus, or just the fuse side.
I assume just the fuse side sense what I understand I should go from batter to bus to fuse to relay anyway.
Just looking for some conformation or correction before I buy a single bus, fuse side only, box.
https://www.waytekwire.com/item/46345/EATON-s-Bussmann-Series-15303-5-2-4-RTMR-Mini-Fuse/
Josh, check out Blue Sea Systems. they have some really nice stuff that is marine grade. I checked out some threads on Expedition Portal, gave me some great ideas.
I run the same AUX Fuse panel with two buss bar, one switched and one non-switched. the only complaint I have is the mini fuses can,t 30 amps even though 30a fuses are available, They don't have enough mass to handle the current and will fail in a very shot time.
