- Terra Firma
Not sure which board this belongs on ... this is probably as good as any.
Doing some sorting and organizing, and I stumbled across a pair of Radio Shack 2" piezo tweeters that are left-overs from a long-ago home speaker project that never went beyond the planning stage. I'm wondering if they could be used in one of the XJs or MJs.
Q1 -- they are rated for 75 watts "peak music power" (RMS not given) and 5,000-25,000 Hz. Could I tap one off each door speaker in parallel and call it done, or would I need some kind of crossover filter? I don't run an amp -- the '88 XJ has a Kenwood head rated 22 watts per channel, and the '88 MJ at the moment still has the OEM AM/FM radio.
Q2 -- if they will work at all in an auto environment, what's the best orientation for them? Should they be pointing right at me or can I tuck them up under the dashboard, out of sight? What about cutting them into the door panels up near the top of the panel (just below the window)?
TIA
TIA
