Programming:
Programming the RKE transmitter access codes requires the use of a DRBIII® scan tool, so if you need ro replace one or want a spare you'll need to visit your local dealer to have this done.
Battery replacement:
To replace the RKE transmitter batteries, use a thin coin to gently pry at the notch in the center seam of the transmitter case halves near the key ring until they pop apart. Replace both batteries with Panasonic model CR2016 (or equivalent). Be certain of course that the batteries are installed with their polarity correctly oriented.
NOTE: The RKE system uses rolling code security. This requires that synchronization be maintained between the transmitter and the receiver. Transmitter battery removal or replacement can cause a loss of sync. If the receiver fails to respond to the transmitter after battery removal or replacement, depress and release the RKE transmitter Unlock button repeatedly while listening carefully for the power door locks in the vehicle to cycle. After between five and eight presses of the Unlock button, the power door locks should cycle, indicating that re-synchronization has occurred.
Jeep Cherokee, Command-Trac, Selec-Trac, Jeep, the Jeep logo, and the Jeep grille are registered trademarks of DaimlerChrysler Corporation. Throughout this web site all the preceding marks & logos are used for identification purposes only. XJ JEEPS is an independent web site and is not affiliated with DaimlerChrysler Corporation. Other trademarks used throughout this web site are the property of their respective owners and are used for identification purposes only.
Our Marketplace is powered by
Quadratec, an independent company providing a service for XJ JEEPS. Any questions or concerns regarding our Marketplace area should be directed to Quadratec's customer support. The name Quadratec, the Quadratec logo and Quadratec.com are trademarks of Quadratec Incorporated. Essentials® is a registered trademark of Quadratec Incorporated, registered with the United States Patent and Trademark Office.
