sford
- Corning CA
In anticipation of adding lockers I purchased an ARB air compressor. I had to remove my wiper washer tank to install it. installation was a breeze four bolts hold the bracket in slide comp. in bracket single bolt clamps together. red wire black wire from comp to battery. wire loom 6 wires, 2 front locker pressure switch wires, 2 rear locker pressure switch wires, 2 pressure cut out wires(cutout 100psi) inside cab on/off switch power, ground, ignition, lights. switch slides easily into existing switch holes.
It seemed to me that the instructions were made for my jeep down to telling me what wires to attach to. easy install
Also purchased the tire inflation kit. Made for comecting to the comp. pressure port with a single outlet however, I one uptm and put a T on the end. Running air to the front and back of the jeep with quick connects.
My question to the masses is this, Can I run an air wrench from this setup???
ARB dosen't say!
Also can I use an air tank to do it?
ARB dosen't say!
