April ROTM Submission Thread
eflores
Greg's place
the theme this month is:
April-
Street/DD nothing bigger than 31's no junkers
Sorry I've been lagging guys. the last cols snap got me double busy with work. I'll do my best to stay up on ROTM
Flores
Rules:
Must be an XJ/MJ based vehicle.
Submissions must be placed in the official ROTM submission thread.
Red letter names only.
First 5 submissions will be voted on.
One or two pictures. Pics must be hosted by the submitter, and sized properly for forum viewing.
NOTE: High resolution versions of the winning rig's pictures submitted must be provided. The original picture file MUST be provided upon winning ROTM, no re-sized or altered pictures will be allowed.
Pictures must be recently taken, maximum of 1 year old allowed.
No copyrighted photos will be allowed. Photo credits and compensation for their use will NOT be provided.
Winning rig must provide permission to use the pictures as sees fit. If you are not the owner/photographer of the picture, their permission must be available in writing (via PM ok). FAILURE TO TO DO SO WILL RESULT IN FORFEITURE OF ROTM TITLE!
Winning rigs will be ineligible for the remainder of the calendar year.
Winner will be featured on the front page of
Only one picture will be selected for the forum front page and calendar, but an additional one can be used to showcase your rig for voting.
demonoid369
1997 S.E. Jeep Cherokee
Front Suspension:
Rubicon Express flex joint short arm
3.5" Nth degree progressive rate coils
Standard white body shocks
Rugged Ridge double shear track bar
Front Axle:
Hp Dana30 axle
Nitro tube sleeves
Home fab LCA skids
Rear Suspension:
Upcountry bastard pack
Home fab shackle relocator
1.5" gmc shackle
S10 shocks
Rear Axle:
Chrysler 29 spline 8.25
Factory LSD
Zj disk conversion
Drive line:
Stock 4.0
Stock aw4
Stock 231
Hack n Tap SYE
Stock front drive shafts front and back
Recovery and Armor:
Factory front tow hooks
Factory front skid
Modified factory Tcase skid
Zj gas tank skid
Ruffstuff uniframe stiffener
Tires and wheels:
Stock steel jeep wheels with 1.25" spacer.
31" kumuro m/t tires.
Interior:
Front sound bar for when I'm doorless.
exterior:
Home fab steering box spacer
Home fab steering box brace
Modified early model tire carrier
iluv83vettes
1999 Limited Jeep Cherokee
Front Suspension:
OME coils and shocks
JKS upper and lower arms
JKS sway bar discos
DPG sway bar disco cables
JKS track bar
ZJ Steering
Front Axle:
Hp Dana30 axle
RuffStuff cover
Home fab LCA skids and upper control arm brace
Rear Suspension:
OME leaves and shocks
JKS shock mounts
DPG Spring plate/bump stops
Rear Axle:
RuffStuff Cover
Zj disk conversion
Drive line:
Stock 4.0
Stock aw4
Stock 242
Tom Woods heavy duty SYE and rear shaft
Recovery and Armor:
Front ARB bull bar with Warn M8000 winch
Rear JCR Vanguard with Adventure Tire Carrier
Front factory skid
Genright 30.5 gallon fuel tank with skid
HD offroad stiffeners front to rear
Tires and wheels:
Dark grey Ecco aluminum wheels
235/75x15 Goodyear Duratracs
Interior:
Factory leather
Sound deadening Peal N Seal all throughout
Head unit delete
Bluetooth to Equalizer to alpine amps
Polk 6.5" speakers
Polk MM8" sub in subthump box
iPad mini mount
other doodads:
5-90 wiring kit
Spectre cowl induction
auxillary fuse relay box
Prime 4x4 ash tray switch panel
10 gauge headlight harness with 100 watt bulbs
Future plans:
ARB lockers
WJ steering and brakes
Truss the 30
transfer case skid
