Stick
Markm80521 said:Except that you can build a front and rear for less than that. I wouldn't exactly call that "stupid." Just depends on wether or not you have the tools or access to the tools. The steel is cheap. Of course, if you are stupid then the fabrication part might be a little difficult, math and imagination are required.
Steel is cheap ?...I'm not sure where your from, but around here steel is hard to find and when you do you feel ripped off when you leave.
