ANYONE NEED A HP 44
BRIANHO13
<- Yum Chocolate
Spring, TX
I have access to 4 of them, 3 with the cast c's and one out of an f250 with the weld on spring perches.
BRIANHO13 said:
Sorry guess I should have stated they are all ot of FORDS.
PM sent
Not necessary. Nobody else ever used a HP44.
Prepmech said:
But...
I know with the cast on Cs that you are stuck using the radius arms, how do you mount the springs?
Using the ferd arms is the easy way to do it, I have seen the cast c's welded to though(infact that's what is under my rig). notice in the first post there is also a f250 axle with the welded on leaf spring perch.
