Anyone make stock style end links for 3.5" lift?
nicpaige
Ohio
My sway bar end link bushings are tore up. Does anyone make a stock style end link that's longer for a 3.5" lift on a 2000 XJ? Or do I have to go with the disconnect style?
I believe the stock length is 8.250" long. The medium length says 8" and the the long 10". That would make the one shorter than stock and the other much longer.
I made my own on the MJ with 3" of lift. Its not hard, cut them in the middle, halfway between the bend and the bolt eye, cut some pipe that will fit over the rod to the length you need, weld the rod to the pipe. Been on the MJ for 5 years now no issues.
You can also make a set out of two pairs and brackets out of the rear link brackets to make a longer set. Mine cost me nothing since I had a second set. Longer and eyes at both ends.
