MikeESoc2
- Staten Island, NY
Got significant leaks dripping from the AW4 in my '87 XJ Limited (started a few weeks after I poured a can of SeaFoam TransTune in)... looks like might be the transmission pan gasket (I hope) ... at 314K miles I never changed the pan gasket nor filter screen ... transmission works great with simple drain-plug fluid changes over the years (~ every 12,000 miles) ... and was not leaking (for last 12 years) until I poured in the can of TransTune last month.
Anyone know what o-ring part# is (where to buy) that seals the top+bottom sections of the AW4 dipstick tubes ?
I've been searching and reading that the dipstick tube sections are possibly 1 of the nasty items during the AW4 trans-pan gasket change, so I want to have the o-ring before I start the gasket-change.
Of all the info that I have found via
and google searches, this is the closest description of the o-ring that I have found:
http://www.ilovejeeps.com/forums/showthread.php?t=17510
If you can't get the tubes apart you can remove the bolt holding the upper tube from the front of the dustcover and pull/twist the entire assembly out from the bottom.
My dipstick tube was rotted together so I had to heat it up. Propane will work.
The replacement O-ring is 3/8 ID x 7/16 OD x 1/16 THK -clean the tube sections so it can slide together tight and use some silicone grease on both sides of the O-ring for next time.
Also: I'm thinking of using the Felpro TOS18685 for the AW4 pan gasket:
http://www.napaonline.com/Search/Detail.aspx?A=FPGTOS18685_0147681907&An=599001+101987+50038+2038004
".... A/Trans Pan Gasket
Product Line: FEL-PRO Gaskets
Part Number: FPG TOS18685
Price: Price Unit: : 8.99 Each
Features & Benefits FelCoPrene Premium Synthetic Rubber Material.; Exceptional Surface Conformability.; Increased Torque Retention. ..."
