Steve_Moore
- Missouri
I have a question or 2 and was wondering if anyone here has some experience. :dunno:
Yup. What you need?
Thanks Ecksjay. It's a CMMG .223. I haven't bought it yet, but am going up to look at it Saturday. I did just get a Charles Daly Defense AR for Christmas this morning, but want another with the detachable handle. I like optics. :cheers: I know I can put some on the handle of my CD, but I really don't want it that high.
You have to remove the flash hider...then the pins holding the gas block in...then remove the gas block...then with the right tool (spanner wrench), take the float tube off. You'll REALLY want to have an upper receiver vice block to hold it. Makes things easier and eliminates the risk of tweaking the upper receiver.
Then when you put your replacement rail on, you want to make sure you've got LOCTITE for all the screws...or it'll come apart on you when you don't want it to.If you get a two-piece rail, you'll need a delta ring (the standard spring loaded ring) to hold it together.
If you don't want to do all that work, you should be able to take the upper to a gun smith who would probably do it for a relatively small fee.
What build is that rifle? I can't tell from the small pics.
He will also need to remove the gas tube.
If he has no experience at this stuff I recommend he ship it off to CMMG or ADCO firearms to have the work done.
