Any mechanical concerns when dropping front from 3" to 1" lift?
jtszymano
Aliso Viejo, CA
I was just wondering if(besides the alignment issues), I will have problems with the bushings etc for all of the steering components etc...Will they be worn too much causing loose steering? I had the lift on for ~2 years...
Do you guys anticipate a problem one way or another??
Thanks JS
According to your sig, you're running the UC.
What lift did you use to attain the 3"? I'd assume you used just a BB. If so, there should'nt be any issues on a 2001.
John
Should be no problems.
J-B,
Well, I used to have a 3" lift then switched to the UC lift and will complete the whole transformation tomorrow AM. Nice pick up on the sig though....
Eagle, thanks.
JS
