any interest in a 97-01 5-speed swap?
mcguyver_xj
Grandby, MA
in my posession i have a full 5-speed swap for a 97-01 xj 4x4 I would like to sell...you would receive:
-clutch and brake pedal assembly
-clutch master and slave cylinder assembly
-5-speed floor plate with inner shift boot
-4x4 linkage
-front and rear driveshafts
-flywheel dust shield
-ax15 tranny mount
-ax15 4x4 external slave
-ecm (its a factory 5-speed with cruise control)
-steering column with wheel and controls
-cruise control actuator
-2 good looking clutches if you decide to use them
-an ok flywheel
-hardware
-and if you want the engine/tranny wiring harnesses out of the donor
