tires are out of balance- swap front to rear vice versa
grease shaft, check pinion u joint
front pinion angle could suck
go under there and tighten up all bolts in the lcas, ucas, trackbar, tres, etc. one more time for good measure.
did you over u joint tighten caps at pinion?
tires outta balance?(again?)-loose a weight.
new shaft is out of balance.
tranny mount
motor mounts
harmonic balancer
just throwing out there a bunch of things id check.
grease nw shaft real good.
once again, pinion angle.
