DansGreyMj
- Nuevo, Ca
I've had some issues with rear springs wrapping instead of compressing. My last set of springs had completely flattened out so I ordered an antiwrap bar kit from Ruffstuff. I swapped in some modified 97-03 F150 springs, which are nearly identical to Mj Leafs, and rather than destroy these springs I'd like to install the antiwrap bar prior to driving. I did some online searching, but the more I read the more confused I got, lol.
I ordered the kit with a 5ft lower bar because as I understand it the lower needs to pivot at the same point as the driveshaft and at the same angle. I was hoping someone had some experience installing one in an Mj and could point me in the right direction. I have the parts to build a crossmember, but space will be tight. The truck is a shortbed 4.0 5spd 231 w/SYE. Any pointers and pics would be greatly appreciated.
Thanks,
Daniel
Thanks,
Daniel
