traitor5150
- Dartmouth MA
O ok I thought the camber was in the inner c guess not.
Starboard M said:If you want to use the small bearing spindles, you have to use chevy knuckles.
The C's are all the same, so it doesnt matter what you use.
traitor5150 said:It would seem to me at least, that you want yor axle side U joint to have some range of motion because if it's a straigt shot it will wear out fast because none of the needle bearing will have any range of motion so they will wear unevenly.. Am I correct in thinking this way or is this not feasable????
traitor5150 said:Ok so waggy width it is but what about the trackbar should I do everything then mount it up and mark where to put the trackbar?? Has anyone here seen the tnt brace in person
Cruzin Illusion said:Here are a few pictures of mine:
If you have any questions feel free to PM me.
Tom
