Another hard starting problem
joes99xj
Redwood city
I have a 2001 XJ have an on going excessive long cranking problem I just replaced fuel pump as other one failed and had lost pressure. It has normal fuel pressure running and it holds pressure for more than 30 min above 30 lbs. It has no codes fresh battery new injectors and cam and crank sensors. However after I installed the pump it just takes alot of cranking before it fires and then runs fine. I do have a code for evap now Po455 large leak. I did find that one of the hose connectors to the canister is dry rotted and cracked in half. I dont believe there is a connection between the two though. Im looking for the hose I think its a dealer only though. Any ideas. Thanks
My 91 XJ won't start after fixing its cranking problem yesterday. I noticed a rotted hose connecting the charcoal canister to the metal line that goes back to the fuel tank. I'm noticing it won't hold fuel pressure (gas only comes out of the Schrader valve when the pump is on prior to cranking). I've read here today that hard-starting issues related to low fuel pressure can be related to check-valves not working. The pump can be working harder when this happens so it may shorten its life.
I'd like to know about the impact of a rotted line also. Rotted is not the best description of my line from the charcoal canister, however. Mine is not dry but somewhat wet and disolving: rubber rubs off on your hands and there are some cracks that may or may not go all the way through. I may have caused it to begin leaking as I moved it while inspecting the engine during my work on it yesterday.
I haven't visited the parts store about this yet but based on past experience I think they will only have fuel lines and vacuum lines that have the same inner diameter on both ends. For this connection the metal line to the tank is about 3/16" but the connection to the cannister is about 3/8" (maybe 5/16"). It seems they shouldn't have to be stretched so much (although there's a clamp on the smaller fitting and no clamp on the canister). I have silicone vacuum hose on hand but I don't think it's supposed to be used where contact with fuel is expected (at least a quick search didn't turn up the answer on that).
Good luck to us both.
Got mine going. The fuel vapor hose wasn't the main issue, but unless I imagined it I smelled a lot more gas after I fixed that.
My main problem was that I accidentally did not reconnect the central wire to the distributor.
