Another distributor question
Troutman
NW Oregon
The power coming to my coil does not go on and off when cranked. I'm thinking either bad trigger in the distributor or the ECU. First is there a way to test to see which is bad? Second, can I replace the trigger in the dist. or do I need to replace the distributor?
This is in a 93 xj sport with a 4.0.
Thanks for any help
Jim
Have you checked your crankshaft position sensor?
