The heater in my 200 dollar XJ is stupid hot! Even when its on low it drives me to crack a window. I would recommend checking the blend door.
This ... :thumbup:
...and if its not that ... double check the heater, coolant circulation.
X 2 on a bit of sheeting in front of the rad if nescessary for a quicker warmup.
Failing that ... buy some thicker socks ... makes a lot more sense than messing with what appears to be a perfectly good cooling system ...
...and unless you have the wrong fanclutch ... theres very liitle dragging of air into the engine bay by the thermal fanclutch ... until the coil spring on the front of it reacts to an air temp of about 160*/170*.
