AMPs Kicker ZX series high power & quality
RWKHausSupply
I replaced both amps in a car I just sold with other lower cost to save the buyer some $. Thinking I would just sell these to help off a bit.
I have two amps. 1-four channel BEAST! This thing is HUGE! like 24" maybe more, long... It was driving 4 sets of CDT gold 6.5's hard loud and clean.
Would liek to get $220 for the 4 channel and $175 for the sub amp. These are double that new, but these have some dust on em. both work perfect! were used maybe a 20 times, the car only had maybe 500 miles since these were installed.
Will sell both for 350$ if interested.
ZX850.4 - Kicker 4 Ch 850 Watt ZX Series Amplifier
Features:RMS Power (4 ohms) 175 watts x 4 chan.
RMS Power (2 ohms) 215 watts x 4 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 425 watts x 2 chan.
Peak Power Output 850 watts
Min. Impedance Unbridged 2 ohms
Built-in Crossover Yes - LP/Full/HP
High-Pass Crossover 50 - 200Hz
Low-Pass Crossover 50 - 200Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB @ 40 Hz
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 120A
Amplifier Type: 4 Channel
Low Impedance Operation
SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
MOSFET Power Supply
KickBass: 0-18 dB @ 40 Hz
Built-In VarLow-Pass operation (50-200 Hz)
High & Low level inputs
Custom tooled gold plated connectors
SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
Cast aluminum EndKaps
RMS Power Ratings:
175 watts x 4 chan. @ 4 ohms
215 watts x 4 chan. @ 2 ohms
425 watts x 2 chan. @ 4 ohms
And then a Matching ZX750.1 Monoblock sub amp that rocks!
mono subwoofer amplifier
375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
variable low-pass filter (50-200 Hz at 24 dB per octave)
variable bass boost (0-18 dB at 40 Hz)
subsonic filter (12 dB at 25 Hz)
wired remote bass level control
Class D design
CEA-2006 compliant
speaker-level inputs
preamp outputs
fuse rating: 40A x 2
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
14-11/16"W x 2-5/16"H x 9-5/8"D
And if you want bling...
you can get skins for these at
http://www.decalgirl.com/design.view/1253
top...
