JL Audio 250/1 v1
tcm glx
NAXJA Member #1033
JL Audio 250/1 Mono Sub Amp. Looking to sell so I can pick up a 500/1 I found. Asking $140, can ship anywhere for another $10.
Link to manual:
http://mobile.jlaudio.com/pdfs/Slash_amps/250_1_MAN.pdf
Specs:
Class D Circuitry
250W RMS @ 1.5 ohms - 4 ohmsTHD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power
Frequency Response: 5 - 50,000 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Differential-Balanced Input Topology: (1 pair of inputs)
On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range, LP or HP)
Bass EQ: variable boost up to 15dB
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual mono speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Dimensions: 10.25"L x 9.25"W x 2.36"H
JL rocks
Good luck with the sale.
This is a powerhouse amp, it will outperform other brand's 1000w amps any day of the week.
good luck with the sale Tony! If I didn't already have a JL in big purp I'd be all over this!
