Alternator light won't shut off.
pabloconrad
Yodels All This only started today: My battery died in no time flat and My alternator light won't shut off even with the ignition off and key out. Battery is flat dead. It is an Optima battery and the alternator is about 5 years old. Did the voltage regulator in the alternator fry? Any help would be appreciated. Thanks in advance.
Your battery isn't compleatly dead, or the light wouldn't be on. Try charging the battery first and see if it goes out once you got a good charge. Most likely it will (when the key is off).
Hope its just the alternator. Later model XJ's have the regulator in the ECU, and it's not cheep.
