Alternative to K&N Drop In Air Filter-True Flow
KY-XJ
G-town, KY
I was doing some research on what other models the air filter on our XJs will fit to see if I could find a True Flow drop in air filter (part #30202) that would work. Well there are several different makes and models the XJs filter is compatible with. The following models use the same air filter...(some of you probably already know this)
1987-2000 Jeep Cherokee
2.5L
4.0L
2001 Jeep Cherokee
4.0L
1987 Jeep Wagoneer
2.5L
4.0L
1988-1990 Jeep Wagoneer
4.0L
1987-1990 Jeep Comanche
2.5L
4.0L
Other makes and models that use the same Jeep XJ and MJ air filter. Use one of these models to search for the model filter that will fit the above applications, if you can't simply search for the part # (30202).
1997 Chevrolet Camaro
5.7L
1997-2006 Dodge Dakota
All Engines
1998-2003 Dodge Durango
All Engines
1994-2001 Dodge Ram 1500, 2500, 3500 (2wd & 4wd)
All Engines
2006 Mitsubishi Raider
All Engines
I know it may be redundant to post all, but I wanted to show what all models use the same filter.
