AK to HI engine code every new part gets worse
Re: Re: AK to HI engine code every new part gets worse
Ok swapped the old PCM in and cant get a code but the engine is still weak and shaking. Only put in 1 screw to see if it was a grounding thing and nadda. I did notice something when I looked under. My passenger side UCA seems to have flexed into my fuel lines and oil pan. The fuel line that goes into the rail is almost kinked off. I'm not sure if fuel issues could cause a code but its something I hadnt noticed before. Any thoughts on that?
Fuel lines are not on the pass side. Those are the trans cooler lines.
