Aftermarket Oil Pressure Gauge
MN-Cherokee
Minnesota, USA
I want to get the Autometer Cobalt Oil pressure gauge for my modded I6.
Here is the question. Will it plug/screw right into the stock oil pressure sensor hole? It says it includes: "1/8" NPT electric sender, 1/4" NPT adapter fitting, and 8' harness."
Brian
the "probe" end of the sensor is actually pretty long--they send you the 1/8" - 1/4" bushing with the though that you might need to use a 1/4" hole.
(and allow for the long sensor probe
just test fit it before u get too far into the project...
Well, I ordered it. Hopefully it will work. But I'll do what you said and try it before I get to far.
Brian
