fishinpolejoe
- Virginia - southwest tip
I've been in the process of replacing the carpet in my '96 XJ with some material I already had on hand. I got the cargo area including the wheel wells and under the back seats, and the entire passenger side "finished" last year. I attempted the driver's side but I just couldn't get the material to lay right on the big hump on the side of the tranny. I gave up for the winter and now that it's getting warm I'm ready to try it again. I'm not trying to do a professional job on it but I want it to look decent when it's finished. I was hoping you guys could help me get over the hump, so to speak. Fitting a flat piece of material over curved surfaces is harder than I expected. You can't copy the factory carpet because it isn't flat like the material. Am I an idiot for even trying this?
I've been trying to do this in the least possible amount of sections. I've basically been taking a big section of material and pushing it down into the floor then trimming off the excess. What I have done actually looks okay to me although there are some little bulges here and there. I'm stumped on the driver's floorboard though. Should I try covering the section with newspaper, tape it all together and cut my material from that? Should I try to do it in smaller sections? What type of glue would work best for attaching them? I'm not sure what the material is but it's something like vinyl I guess.
Any advice would be appreciated.
This is the material. It's around 4' wide, maybe 1/16th" thick. It's pliable, cuts easily enough but doesn't rip.
Here's the first piece I put in. Like I said, I'm not going for perfection. You can see how the material doesn't want to lay down. It needs to come back out later for replacement floor pans so it doesn't matter too much.
